Subject: portfolio module
Dave
21 Jan 2008 6:13 AM
Hi I am creating a portfolio site for users at my university. I need to create a new page for each user which contains a gallery that i have bought, a utube viewer module, some html modules and a links module. I need to be able to change the permissions on all modules at the same time so that the users can modify the content of the modules but not the page. At the moment I am using page as a template and I have to set the permissions in each module separately. Is there anything that is available that can accomplish this task.
It would be nice to be able to create the page with all the relevant permissions set for each user automatically. I am thinking of creating a custom module but I am unsure of where to start with this. Any help would be very usefull.
21 Jan 2008 8:18 AM
You might want to check My Profile from dnnFusion.
RE: Cannot view host filespace using text/html editor by NonStopMark
Hi Joe, The problem has gone away. May have been a caching issue. Thanks for posting. DNN : ht...
Firefox Does Not Display WMV File In Media Module by johnmk777
Hi All,I can't believe I am having such a hard time finding and answer to this question.  I have see...
