Subject: I need a module for advanced search
lizok
10 Jan 2008 11:50 AM
I need this functionality : to make database (adress, profession, specification, etc) that can be editable by administrator BUT each person of database will be exist by monthly payment ; user will make advanced search by some quantity of fields, checkbox, dropdownmenu, etc AND appearing of results can be modified. Is this possible to find something like this ? Anybody can advice something? Thanks alot.
11 Jan 2008 2:17 AM
It might be worth looking at XMod to see if it will cover your needs, however you may find that in this case you need to program your own custom module.
Forums > DotNetNuke® > Modules - What's needed? > I need a module for advanced search
