Subject: e-Survey?
mgordon
29 Aug 2008 9:25 PM
I need a module that will do the following:
When a person comes to a specific page (recreation guide web page), I need something that checks their IP address.  If that IP address has not been here before, I need a window that pops up on top of the web page that asks them if they would like to take a brief survey.  They can select "Yes" or "No".  If they select Yes, it takes them to a e_survey page about that particular page.  When completed it takes them to the page they were trying to get to in the first place.  If they select No, it registers their selection and closes the popup window and lets them go about their merry way.
Anyone have any ideas on this?
Mark
Mark Gordon
Webmonkey
