Subject: Not able to add module
obautista
16 Aug 2008 12:09 PM
I am new to DNN.  I am using 4.8.4, Startkit.  I created a test module and attempted to add it to a page I created.  I am getting the following module load exception error message.  Can anyone help?
ModuleId: 374
ModuleDefId: 99
FriendlyName: OscarModule
ModuleControlSource: DesktopModules/OscarModule/OscarModule.ascx
AssemblyVersion: 04.08.04
PortalID: 0
PortalName: My Website
UserID: 1
UserName: host
ActiveTabID: 54
ActiveTabName: OscarModule
RawURL: /dotnetnuke/Default.aspx?TabId=54
AbsoluteURL: /dotnetnuke/Default.aspx
AbsoluteURLReferrer: http://localhost/dotnetnuke/Default.aspx?TabId=54
UserAgent: Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 6.0; SLCC1; .NET CLR 2.0.50727; Media Center PC 5.0; .NET CLR 3.0.04506; InfoPath.2; .NET CLR 3.5.21022)
ExceptionGUID: 71eeb9be-faca-4888-8e21-4df7c4878594
InnerException: Unable to cast object of type 'ASP.desktopmodules_oscarmodule_oscarmodule_ascx' to type 'DotNetNuke.Entities.Modules.PortalModuleBase'.
FileName:
FileLineNumber: 0
FileColumnNumber: 0
Method: DotNetNuke.UI.Skins.Skin.InjectModule
StackTrace:
Message: DotNetNuke.Services.Exceptions.ModuleLoadException: Unable to cast object of type 'ASP.desktopmodules_oscarmodule_oscarmodule_ascx' to type 'DotNetNuke.Entities.Modules.PortalModuleBase'. ---> System.InvalidCastException: Unable to cast object of type 'ASP.desktopmodules_oscarmodule_oscarmodule_ascx' to type 'DotNetNuke.Entities.Modules.PortalModuleBase'. at DotNetNuke.UI.Skins.Skin.InjectModule(Control objPane, ModuleInfo objModule, PortalSettings PortalSettings) --- End of inner exception stack trace ---
Source:
Server Name: BAUTISTA-LAPTOP
16 Aug 2008 6:36 PM
It looks (from the "unable to cast" error message) like your module doesn't inherit from the DotNetNuke.Enties.PortalModuleBase class.
Forums > DotNetNuke® > Modules - What's needed? > Not able to add module
RE: Cannot view host filespace using text/html editor by NonStopMark
Hi Joe, The problem has gone away. May have been a caching issue. Thanks for posting. DNN : ht...
Firefox Does Not Display WMV File In Media Module by johnmk777
Hi All,I can't believe I am having such a hard time finding and answer to this question.  I have see...
