Subject: Custom T-Shirt Creator
mbatestech
10 Jun 2008 8:52 AM
I would love to see a module that can create Custom t-shirt designs for building t-shit printing store websites like this http://www.harboarts.com/shirtdesigner/
If anyone knows of such a module that even comes close to pulling something like that off, I would be one happy dude.
22 Jun 2008 8:45 AM
Are you aware of CafePress.com?
Forums > DotNetNuke® > Modules - What's needed? > Custom T-Shirt Creator
