Subject: Require Help
cindrella
14 May 2008 12:17 PM
My problem is if a person's login is failed ,a message is generated "click here " to reset passoword,so through this hyperlink an email is to be sent with a link to reset the password .
Any suggestions are welcome
17 May 2008 8:14 PM
Could you please state what the problem is again?
