Subject: weather display
eureka
13 May 2008 4:54 AM
Hi Lee and Joe
I would like to display a current weather report without the advertising tags to accompany it, do you know of any?
Ideally an advert free, skin object weather display would be nice.
 I am currently using the Weather Module from http://www.bitethebullet.co.uk/  but it includes a yahoo link.
Lynn
17 May 2008 8:14 PM
Let us know if you find a good one, Lynn.
