Subject: variable of username
meenu
12 Mar 2008 1:29 AM
dear friends
i am using DNN 04 08 and visual studio 2005
i created a new module in my DNN0408.i installed this module it is working properly.
in my module i have a button.
in that button click  i done this follwing code.my web is coming properly.from here i want to pass my dnn current username also with this link. how?
  Page.ClientScript.RegisterClientScriptBlock(Me.GetType(), "popup", "window.open('http://192.168.151.15:88/webform1.aspx','','scrollbars=yes,menubar=no,height=600,width=800,resizable=yes,toolbar=no,location=no,status=no')", True)
 can anybody help me?
which is the variable available in dnn for current user?
regards
12 Mar 2008 8:47 AM
The current user's information is available through the DotNetNuke.Entities.Users.UserController class. You will want to get UserInfo.
meenu
12 Mar 2008 11:28 PM
thank u very much for ur support.
i done it.
Dim objUser As UserInfo = UserController.GetCurrentUserInfo
Dim user4mapping As String
user4mapping = objUser.Username
Page.ClientScript.RegisterClientScriptBlock(Me.GetType(), "popup", "window.open('http://192.168.151.15:88/webform1.aspx?username=" & user4mapping & "','','scrollbars=no,menubar=no,height=650,width=screen.width,resizable=no,toolbar=no,location=no,status=no')", True)
Forums > DotNetNuke® > Modules > variable of username
Glad it's working!
Firefox SWF file by ce221
PayFlow Link by murphydolores
RE: Send email with Dynamic Forms Results by jesp17
Hi Lee,I've asked DataSprings if there is a way to solve my problem (wish). Here is a reaction:I don...
Background Music by kparker
Do you know of any module that I can use to play background music on a single page?  Or do you have ...
I did this several years ago, so I think that what I found must have been in the "Professional DotNe...
DNN Creative Subscribe
