Subject: HouseMenu shows up empty
solidwave
08 Dec 2007 6:41 PM
I've installed HouseMenuModulePA_01.04.01.beta on DNN 4.7. For the life of me I can't get HouseMenu to show up in my skin.  I was able to get the SimpleRed leaf skin to load correctly and the menus worked, but on my skin the menus don't show up at all.  When I view the source, I see an empty unordered list with a HouseMenu CSS attribute.  I've tried in vain to see what gives by checking my HTML against SimpleRed, but can't see anything.  I created an empty skin.xml file to make sure I wasn't doing anything funny. Here's my code:
  • [TITLE][HOUSEMENU:1]
  •    Search
       [SEARCH]
   [CONTENTPANE]
Additional Info
            [HOUSEMENU:3]
Here's my XML file.  I included only one of the menus:
  xml version="1.0" encoding="utf-8" ?>
- <Objects>
- <Object>
  <Token>[HOUSEMENU]Token>
- <Settings>
- <Setting>
  <Name>ScopeName>
  <Value>-1Value>
  Setting>
- <Setting>
  <Name>ShowAdminName>
  <Value>TrueValue>
  Setting>
- <Setting>
  <Name>IsRecursiveName>
  <Value>TrueValue>
  Setting>
- <Setting>
  <Name>OrientationName>
  <Value>VValue>
  Setting>
- <Setting>
  <Name>ModeName>
  <Value>SValue>
  Setting>
- <Setting>
  <Name>CssElementIdName>
  <Value>HouseMenuNavValue>
  Setting>
  Settings>
  Object>
  Objects>
Forums > DotNetNuke® > Modules > HouseMenu shows up empty
RE: Server Application Unavailable from localhost by picoallen
OK, I've got things working better now. Not sure why though as I lost track while following all the ...
e-Survey? by mgordon
I need a module that will do the following:When a person comes to a specific page (recreation guide ...
