Subject: Need help on Banner Module display
ramjammas
31 Oct 2007 10:37 PM
DNN V 4.3.5 website I have created a couple of text banners in the same group via Admin>Vendors and displayed them via the Banners Module.
All is fine EXCEPT that I get a random number displaying below the text that displays as a text link (using the defined CSS text link properties) and links to the same Page as defined in the page to link the text banner ad to in the Vendor BannerAd Admin menu screen.
I never had this problem on previous DNN versions NOR do I get it where I do not specifically link the banner ad text to a specific page on the website!
What is this number (is it some sort of tracking ID?) and more importantly how do I getr rid of it so it does not display in the Banner Ad?!
See Example below or visit http://www.tuggerahdoctors.com.au - bottom right hand side of page:
Permanent GP Position
Job ID: 0077 Experienced physician with special interests in paediatrics and/or diabetes required for a Lisarow NSW general practice.
24 month minimum contract starting Jan 2008.
57
MikeT
Forums > DotNetNuke® > Modules > Need help on Banner Module display
RE: Pop up window by jncraig
Pop up window by yerann
