Im facing one issue in Event module. When i try to add events the following error has occur
Error: Events is currently unavailable.DotNetNuke.Services.Exceptions.ModuleLoadException: Failed to load viewstate.
The control tree into which viewstate is being loaded must match the control tree that was used to save viewstate
during the previous request. For example, when adding controls dynamically, the controls added during a post-back must match the
type and position of the controls added during the initial request. ---> System.Web.HttpException: Failed to load viewstate.
The control tree into which viewstate is being loaded must match the control tree that was used to save viewstate during the
previous request. For example, when adding controls dynamically, the controls added during a post-back must match the type and
position of the controls added during the initial request. at System.Web.UI.Control.LoadViewStateRecursive(Object savedState)
at System.Web.UI.Control.LoadChildViewStateByIndex(ArrayList childState) at
System.Web.UI.Control.LoadViewStateRecursive(Object savedState) at
System.Web.UI.Control.AddedControl(Control control, Int32 index) at
System.Web.UI.ControlCollection.Add(Control child) at DotNetNuke.Modules.Events.Events.LoadModuleControl() ---
End of inner exception stack trace ---
please let me know the solution as soon as possible
Anu
<!--Session data-->[script removed]
