Subject: The Read More link does not work for Link Type = file
Doru Pirvu
06 Jul 2009 6:21 AM
I moved my DNN website to other hosting.
On the old hosting all modules were working properly.
On the new host the Announcements module has problem. I have problem with Read More link when Link Type is set to file
Ex. I set the link to file http://www.domain.com/portals/1/test.txt
URL created by the module is http://www.domain.com/LinkClick.aspx?link=test.txt&tabid=118&mid=681
The problem is that when I click the Read More link, it is opened an empty text file (both by download and by open directly)
When I type the URL http://www.domain.com/portals/1/test.txt then the file is opened with the its content.
I am using Announcements module 03.01.00 on DNN 337.
If anyone knows a good solution to this please let me to know.
Any help would be greatly appreciated!
Doru Pirvu
[script removed]
06 Jul 2009 7:34 PM
You will probably have to recreate the links. Edit the module content, highlight the link, and then use the link tool.
Forums > DotNetNuke® > Modules > The Read More link does not work for Link Type = file
Localizing Skins and css dynamically based on language selected by sadabahar83
Hi, I want to dynamically assign a skin and CSS based on the language selected. Different pag...
Recomended DNN version? by lolorn
What version of DNN would be recommended for creating a new site? Has DNN 5.2 turned out to be as st...
query regarding page options by kaustav_kar
Hi,My site will have two Home pages, one for a new visitor and one for a returning visitor.   Is the...
RE: Plz Help. Page_Load_Exception by zaidkhan
URL of My website is www.pafkiet.edu.pk
Few new skins by Rozo
Skins for DNN and other CMS. www.stelg.com
RE: Plz Help. Page_Load_Exception by jncraig
Can you provide a URL?
RE: Custom Textbox Size by jncraig
For the second part, you can switch the editor to source mode and enter unstyled text. For the fi...
RE: Picture size limits by jncraig
The little red x's generally mean that the link to the image is broken.  My guess is that you have a...
RE: Uploading an MP3 file to my website by jncraig
web.config is in the root directory of your DotNetNuke installation.  ALWAYS (!!) make a backup copy...
RE: Customizing registration page by kana
Picture size limits by Doug_s
I'm lost - I've just changed host and a few thing that used to work don't, plus I can't display anyt...
RE: How to Limit Access to Administrator Modules in DotNetNuke 5 - issue 50 by samjst
Hi, Did you manage to solve the problem? I'm facing the same issue: users with access to add and...
Ealo Tab Localization help by sadabahar83
hi, I have installed Ealo Core Api and Ealo tab localization and ealo Menu provider. menu is wor...
Custom Textbox Size by PopeOMalley
Hello everyone,Do you know if there is a way to customize the size of a textbox control on the Manag...
RE: DotNetMushroom RAD by md-pv
That sounds interessting too. I'll check it. Thanks a lot.
thanks alot for replying Sir,Well.. my Under Construction Redirect issues are more general and they ...
RE: Uploading an MP3 file to my website by billkidwell
Joseph - I added the mp3 extenison to the list. It still diod not work. No error message but it did ...
Two things could go wrong.First, mp3 might not be an allowed file type.  You should have received an...
Joseph - Thanks, but I see my post was unclear. I tried to upload the MP3 and teh uplaod failed. No ...
RE: What are best tools for localization? by jncraig
The modules from Apollo and the EALO and Magic Content modules are the ones that I would use.  I don...
DNN Creative Subscribe
