Hi I created a container .In that container I am using [ACTIONBUTTON] token.i want to change the image for that control.By default one image and on mouse over other image.it possible to change the image on any event for actionbuttont token.
This is the answer from Lee that helped me to change the icons: http://www.dnncreative.com/Forum/ta...fault.aspxI am changing the icons in this way, hope this helps somehow. Thanks
