Hello ,
i have created one procedure having name servicerequestlist and also properly putting it in all component files
and that function returing arraylist ....
when i run the code it gives me following exeception..
Message "Exception has been thrown by the target of an invocation." String
and this is stack trace if
StackTrace " at System.Reflection.RuntimeMethodInfo.InternalInvoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture, Boolean isBinderDefault, Assembly caller, Boolean verifyAccess)
at System.Reflection.RuntimeMethodInfo.InternalInvoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture, Boolean verifyAccess)
at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture)
at System.Reflection.RuntimePropertyInfo.SetValue(Object obj, Object value, Object[] index)
at DotNetNuke.Common.Utilities.CBO.CreateObject(Type objType, IDataReader dr, ArrayList objProperties, Int32[] arrOrdinals) in D:\DNN\components\Shared\CBO.vb:line 122
at DotNetNuke.Common.Utilities.CBO.FillCollection(IDataReader dr, Type objType) in D:\DNN\components\Shared\CBO.vb:line 197
at Infynita.DNN.Modules.NewServiceRequest.Business.Service_Req_MasterController.ServiceRequestList(Int32 Cno) in D:\DNN\DesktopModules\NewServiceRequest\Components\NewServiceRequestController.vb:line 46
at Infynita.DNN.Modules.NewServiceRequest.NewServiceRequest.Page_Load(Object sender, EventArgs e) in D:\DNN\DesktopModules\NewServiceRequest\NewServiceRequest.ascx.vb:line 113" String
plz tell me where i m wrong or missing any thing while doing this
plz help me out
parag
