Subject: HouseMenu doesnt work
blablubb123
03 Jul 2008 8:34 AM
hello there!
I wanted to use the skin "Andreas 01" from dnncreative.com.
i downloaded the HouseMenu from "House Of Nuke" and installed it. at first, it worked, but not the way I wanted it to.
so when i installed the skin and the containers it all looked really good - except for the menu.
even after using the template (and deleting everything i had done before); the menu looked like a normal unordered list in html.
04 Jul 2008 7:34 AM
Check out this forum post for some quick tips with HouseMenu
Forums > DotNetNuke® > Modules > HouseMenu doesnt work
