Subject: Document management Modules
jfitzgerald
21 May 2008 5:23 AM
Hi Guys,
I'm trying to find out if dnn has an advanced document management module?
Can anyone help??
Many thanks
Jason
21 May 2008 7:25 AM
What functionality would such a module have?
jfitzgerald
21 May 2008 8:05 AM
Ideally the following
  • Check in\ out facility – Giving audit trail of who has ‘checked out’ the document for amendment & review.
  • The ability to have secure roles – i.e. I could set the user access to an individual or a role.
  • E-mail compatibility – auto e-mail when the document has been flagged for review.
  • Reminders sent to document owners when the document is ready for review.
  • Unique, automatic document numbering system
  • Document revision control
Any ideas??
Cheers J
22 May 2008 7:57 AM
I'm not aware of a module with all of these features. If you find one, please let us know.
25 May 2008 9:21 AM
You might want to take a look at Document Exchange 4. It's available at Snowcovered.com.
jlpardo
13 Jun 2008 5:53 AM
I'm using now Xepient Open Document Library and is great for me
It's possible to download a Trial Version of this module here: http://www.opendnn.net/Downloads/tabid/95/Default.aspx?xsfid=17
without time limitation, but you can only have 3 documents / folders.
14 Jun 2008 10:49 AM
Thanks for the update!
kennster
25 Jun 2008 2:21 PM
I sell a module I have developed over the years on Snowcovered.com for $49.00. It includes virtually all the features of the other two DMS modules on Snowcovered, minus WebDAV support. If you don't need WebDAV then my module may be just what you are looking for. I don't offer a trial version any more because licensing was proving to be a huge pain in the ass, but I do have a full demo available on my web site at http://host.aciasoftware.com, and the module on Snowcovered here
-Kenneth S Courtney
ACIASoftware.com
Forums > DotNetNuke® > Modules > Document management Modules
Glad you sorted it, thanks,
