You need to
Register
for free and
Forums
Search Forum
Advanced Search
Topics
Posts
Unanswered
Active Topics
Forums
DotNetNuke®
DotNetNuke® Questions
Upgrade DNN 4.9 to 5.01 - run time error
Last Post 07/23/2009 8:52 AM by
. 6 Replies.
Oldest First
Most Recent First
Prev
Next
Author
Messages
ashio
07/20/2009 7:32 AM
Help...
I've upgrade from 4.9 to the latest version of DNN and have the following error message:
I've followed the tutorials... not sure what I've done wrong to get the error message. Can someone advise how i can fix this please? Thank you!
Runtime Error
Description:
An application error occurred on the server. The current custom error settings for this application prevent the details of the application error from being viewed remotely (for security reasons). It could, however, be viewed by browsers running on the local server machine.
Details:
To enable the details of this specific error message to be viewable on remote machines, please create a
tag within a "web.config" configuration file located in the root directory of the current web application. This
tag should then have its "mode" attribute set to "Off".
<!-- Web.Config Configuration File -->
Notes:
The current error page you are seeing can be replaced by a custom error page by modifying the "defaultRedirect" attribute of the application's
configuration tag to point to a custom error page URL.
DNN MVP
07/20/2009 8:12 AM
If you make the recommended change to web.config and set the custom error mode to "Off" you may get some more information.
Joe Craig,
Patapsco Research Group
Complete DNN Support
ashio
07/20/2009 10:37 PM
Hi Joe,
Yes, I have done that... same error message.
Can I delete everything (and start again) by FTPing all the DNN 5.01 files & folders over again?
(Just got Godaddy hosting - it installed 4.9, but I want 5.01 version)
proarch123
07/21/2009 8:16 AM
DNN 4.9.4 supports upto .NET framework 2.0.
DNN 5.1 supports .NET framework 3.5 also.
When you upgrade your application from DNN version 4.9.* to 5.1 your web.config file will be modified with various .NET 3.5 framework supported tags.
You might be having .NET framework 3.5 on your local development machine but, not on your server.
Make sure that your server has also .NET framework 3.5 framework.
Proarch.
DNN MVP
07/21/2009 8:36 AM
Yes, you can delete everything and start over.
If you can restore your 4.9 site, you can also export the portal, so that you can re-import it to Version 5. Make sure that the new version is 5.1.0.
Joe Craig,
sypa
07/23/2009 5:30 AM
Can you confirm whether or not 5.1 will run on either framework 2.0 or 3.5 please? thanks.
DNN MVP
07/23/2009 8:52 AM
Yes, either framework. The next release will, I believe, require 3.5.
Joe Craig,
Special Bonuses
--Subscriber Bonuses
--Readers Offers
Users Lounge
--Announcements
--DNN Creative Articles
--Everything Else
--Membership
--Site Review Please!
--Testimonials
--Podcasts
DotNetNuke®
--DotNetNuke® Questions
--Modules
--Modules - What's needed?
--Quick Tips
Hosting
Skinning Toolkit
--Skinning Toolkit
UK DotNetNuke User Group
Forums
DotNetNuke®
Can you Run Xcode in Linux?
by Aman Singh
by Aman Singh
by Ryan
by DNN User
by DNN User
by DNN User
by Melanie Weaver
Events Module for DNN V5?
by Tugboat
"Ghost" TabID Number?
by Tugboat
RE: DNN Load Testing
by ayman sharkawy
Publish All Pages
by NSUOK
by Donald
by Donald
RE: Document Collaboration
by Nick Davern
by Donald
by Jakir HM
by peter
