Subject: 2 DNN Installs to one server
gho3t
10 Jan 2008 2:11 PM
Hello All
I have 2 servers running DNN and SQL 2005
1 Server has 2 DNN Sites, the other server has 1 site.
I want to consolidate them to a one New server.
Any Ideas would have me get started.
10 Jan 2008 9:02 PM
Depending on the modules that you use, you might get a good bit of this done by exporting a template (including content) of the single site on one server, and then creating a third site on the other server using that template.
11 Jan 2008 2:02 AM
I would try to create a backup of the DotNetNuke installation files and database and restore them on the other server. - just like you would if you are transferring a localhost installation to a live website.
These may come in handy:
Find and Replace SQL queries for DotNetNuke
(To fix problems after transferring a localhost database to a live website and other useful functions)
How to synchronize local and live DotNetNuke installations
11 Jan 2008 9:01 AM
If, as Lee suggested, you want the two installations on a single server, then follow his advice and not mine. My advice was intended to consolidate all three sites into a single DotNetNuke installation.
ProfDev
16 Jan 2008 1:52 PM
Another way is to create virtual machine(s) with MS Virtual Server or VMware, or Virtual PC. You can convert one of the servers to virtual machine.
Depends on your needs actually.
Forums > DotNetNuke® > DotNetNuke® Questions > 2 DNN Installs to one server
Need UK Hosting by Liz
Web.config Error by derpir
Yahoo Answers by cdtguru
RE: Videos by clippy
skinning trouble by derpir
RE: Template Issue by jncraig
