Subject: Redirect All users after logout
csinva
16 Oct 2007 1:08 PM
I'm running DNN 4.5.03 on GoDaddy, I say that just incase someone tells me to upgrade.
I need to be able to redirect everyone who logs out back to the main default web site not back to the login page.  Currently my DNN is installed in /members, so I need to redirect everyone back to www.mysite.com
Chris
Nuke Master I
Nuke Master I
16 Oct 2007 3:35 PM
On the User Settings Page, available from the Users page ( Admin >> Users >> UserSettings), there are options to redirect after registration, login, and logout.
Nuke Master I
Nuke Master I
16 Oct 2007 3:49 PM
Hmmm ... I just saw some comments on the DotNetNuke forum that these settings might not be working correctly.
csinva
17 Oct 2007 11:23 AM
I saw that as well, but was hoping that someone my have another work around for that issue.
Nuke Master I
Nuke Master I
17 Oct 2007 11:41 AM
Have you tried using the links on the User page??
csinva
22 Oct 2007 11:28 AM
I looked more into it and the problem is that it only allows me to select a page not just type in a page, like http://mysite.com/default.
Nuke Master I
Nuke Master I
22 Oct 2007 4:06 PM
I'm not sure I understand the distinction.
SupaHoopsa
30 Jun 2008 4:52 AM
Did you manage to resolve this?
I have a similar problem whereby when a user logs out of my Portal, I need to redirect them to an external web site.
I have created a thread on the DNN forum, but haven't had any help yet!
http://www.dotnetnuke.com/Community/Forums/tabid/795/forumid/108/threadid/238344/scope/posts/Default.aspx
Nuke Master I
Nuke Master I
30 Jun 2008 8:54 PM
You could try redirecting to a page that really is a link to an external site.
Create the page, and in the page settings make it a link to the external site. Then go to User Settings and set the redirect after login page to that page.
SupaHoopsa
01 Jul 2008 3:58 AM
I have tried that.
I created my own logout page and using the advanced properties int he page settings I set a the link URL to the external page I wanted to redirect my users to.
However upon logout, it correctly sends me to my logout page, but it doesn't activate the link URL to the external page. Rather it just stays on my logout page.
Any ideas?
Forums > DotNetNuke® > DotNetNuke® Questions > Redirect All users after logout
RE: PowerDNN by jazzylily
RE: PowerDNN by DavidWSnow
RE: PowerDNN by mgordon
Great!
RE: PowerDNN by MobileNow
