Yes we are currently editing videos covering how to transfer a localhost to live site, how to transfer a live site to a localhost site, and how to fix problems with urls when you transfer a localhost site to a live site.
Unfortunately there isn't a solution to the tab id problem when transferring the content using the template method apart from manually editing the links. - You may be able to use something such as the technique outlined here:
http://www.bi4ce.com/Support/Forums...fault.aspxWhere you can use find and replace to change URLs, but you may come across conflicts ie:
(Left tab IDs are the live site, right ids are the localhost original tab ids that you need to convert)
Find all URLs with a tab ID of 56 and change them to a tab ID of 70
find all URLs in a tab ID of 70 and change them to a tab ID of 60
All of those tab ids above will now be using no. 60 instead of 70 and 60
If you can wait till the 1st/2nd July, the video tutorials in issue 22 will demonstrate the preferred method of transferring a localhost installation to a live site.
