orus casino
bodog
ruleta
luckia
betano
sportium
spin casino
stakes
3 reyes
888
lottoland
coolbet
777 casino
gana777
betfair
bwin
yak casino
ivy casino
oddschecker
red casino
netbet
william hill
vip casino
rey casino
marathonbet
dafabet
sol casino
1bet
winland
bet777
parimatch
18bet
888casino
campobet
mostbet
ganabet
rushbet
betcris
betsson
lucky
novibet
winner
winpot
betmaster
betmexico
cancun
playcity
strendus
pokerstars
codere
caliente
fun88
bbrbet
1win
10bet
betway
pin up
spinbet
7cslot
pickwin
spin bet
mr fortune
w88
pragmatic
gamdom
crasher
jojobet
betmex
bcasino
foliatti
winner mx
bets 10
big bola
bet master
inbet
7slots
lucky day
m777
mexplay
luckydays
bet caliente
1x
plinko
You need to
Register
for free and
Forums
Search Forum
Advanced Search
Topics
Posts
Unanswered
Active Topics
Forums
DotNetNuke®
DotNetNuke® Questions
HouseMenu Skin Object Ver 1.4
Last Post 06/11/2007 6:48 AM by
. 2 Replies.
Oldest First
Most Recent First
Prev
Next
Author
Messages
KMOwen
06/10/2007 6:21 PM
Hi Lee
I am using the HouseMenu skin object Ver. 1.4 with a CSS skin on DNN453. The menu is configured as a Horizontal "Drop Down" Menu using one of the CSS templates that comes with the skin object.
The menu works OK in Firefox Version 2. However, in IE7 I have noticed that the drop down sub-menus do not automatiaclly collapse when you hover over a new main menu item. This has the effect of multiple drop down sub-menus being visible until a menu item is selected. If no menu item is selected then they continue to be visable (IE: "dropped down")
I have noticed via the HouseofNuke Forums that you have recently done some testing with this version of the HouseNMenu Skin Object and DNN453. Have you come across the problem and do you know how to fix it?
KMOwen
06/10/2007 7:53 PM
Hi Lee
I have done it bit more testing. It appears that the drop down sub-menus collapse if I exit (IE: Move the cursor off) the main menu item "block" from the BOTTOM or the TOP of the main menu item "block". If I "exit" the main menu item "block" from the LEFT or the RIGHT (IE: Just move my cursor along the list of main menu items horizontally) the drop down sub menus appear but do NOT collapse.
I have checked the CSS code for the menu template and "display: inline;" is used instead of "display: block;". I think you mentioned that "display: inline;" can cause some problems. Do you think that this may be the cause?
Kevin
06/11/2007 6:48 AM
Hi Kevin,
Yes I've recently done some testing, however these tests were for a static menu. - I have only used static menus as when I tested dynamic menus (this was v1.3) they did not produce reliable results in various browsers.
It could be all sorts of problems, basically I would use the methods outlined in this tutorial:
to test the CSS code / make changes / strip out sections etc. to try and find a solution.
DotNetNuke Video Tutorials
The Skinning Toolkit
DotNetNuke Podcasts
Twitter:
www.twitter.com/DNNCreative
Special Bonuses
--Subscriber Bonuses
--Readers Offers
Users Lounge
--Announcements
--DNN Creative Articles
--Everything Else
--Membership
--Site Review Please!
--Testimonials
--Podcasts
DotNetNuke®
--DotNetNuke® Questions
--Modules
--Modules - What's needed?
--Quick Tips
Hosting
Skinning Toolkit
--Skinning Toolkit
UK DotNetNuke User Group
Forums
DotNetNuke®
Can you Run Xcode in Linux?
by Aman Singh
by Aman Singh
by Ryan
by DNN User
by DNN User
by DNN User
by Melanie Weaver
Events Module for DNN V5?
by Tugboat
"Ghost" TabID Number?
by Tugboat
RE: DNN Load Testing
by ayman sharkawy
Publish All Pages
by NSUOK
by Donald
by Donald
RE: Document Collaboration
by Nick Davern
by Donald
by Jakir HM
by peter
