Subject: 4.5.1 Portal templates
markp
29 Apr 2007 10:56 AM
I create a portal template, using chickensnow.info at first I tried using the include resources, then without, also under different names, results each time.
When I try, using the site wizard to bring the template into another site inside the same host umbrella , I am getting not a valid dnn template.
any ideas?
markp
29 Apr 2007 7:18 PM
I have an updated schema file that will fix these errors so that you can also export and import those other properties.
You can get it at http://www.snapsis.com/downloads/portal.template.xsd.zip
For those who are unfamilliar, the portal.template.xsd file should be placed in the /admin/Portal folder.
This was reported on Dotnetnuke. There is a problem with the protal schema. This file fixed my problem and others that people were haveing.
30 Apr 2007 4:31 AM
Thanks for the info Mark
Forums > DotNetNuke® > DotNetNuke® Questions > 4.5.1 Portal templates
Need UK Hosting by Liz
Web.config Error by derpir
Yahoo Answers by cdtguru
RE: Videos by clippy
skinning trouble by derpir
RE: Template Issue by jncraig
