Subject: How to delete a post from forum/blog module?
puremood_2002
16 Apr 2007 1:04 PM
I can't figure out following functionality in DNN, Please shed some light:
In forum module, how to delete a post?
In blog module, how to delete a comment?
Forums > DotNetNuke® > DotNetNuke® Questions > How to delete a post from forum/blog module?
Firefox Does Not Display WMV File In Media Module by johnmk777
Hi All,I can't believe I am having such a hard time finding and answer to this question.  I have see...
