George Tang
Nuke Ace Posts:54
01/17/2007 3:53 AM |
I have copied all the update files of DNN 4.4 to the existing folder. I also copied the appSetting section in the release.conf to replace the one in web.config. After that, i can update the current dnn, however, after the update and click on the access portal link, it cannot display the page.
I would like to know what to do to save my site.
Thank you. |
Lee Sykes DNN Creative Staff
Nuke Master VI Posts:4945
George Tang
Nuke Ace Posts:54
01/17/2007 4:11 AM |
i have done so but it cannot display page Thank you |
George Tang
Nuke Ace Posts:54
01/17/2007 4:54 AM |
No, it just shows nth.. something like cannot display page |
George Tang
Nuke Ace Posts:54
01/17/2007 5:21 AM |
No, i don't have an url. actually i am still trying in localhost, or do u want to have a look on the files?
Thank you |
George Tang
Nuke Ace Posts:54
01/17/2007 5:23 AM |
After trying the links, i have the following error
Server Error in '/DotNetNuke Website2' Application. --------------------------------------------------------------------------------
Server cannot append header after HTTP headers have been sent. Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.Web.HttpException: Server cannot append header after HTTP headers have been sent.
George Tang
Nuke Ace Posts:54
01/17/2007 5:30 AM |
ok ,sure. This is the new web.config <!-- register local configuration handlers --> <!-- the requirePermission attribute will cause a syntax warning - please ignore - it is required for Medium Trust support--> <!-- Connection String for SQL Server 2005 Express --> name="SiteSqlServer" connectionString="Data Source=.\SQLExpress;Integrated Security=True;User Instance=True;AttachDBFilename=|DataDirectory|Database.mdf;" providerName="System.Data.SqlClient" /> <!-- Connection String for SQL Server 2000/2005 name="SiteSqlServer" connectionString="Server=(local);Database=DotNetNuke;uid=;pwd=;" providerName="System.Data.SqlClient" /> --> <!-- Connection String for SQL Server 2005 Express - kept for backwards compatability - legacy modules --> <!-- Connection String for SQL Server 2000/2005 - kept for backwards compatability - legacy modules --> <!-- Host Header to remove from URL so "www.mydomain.com/johndoe/Default.aspx" is treated as "www.mydomain.com/Default.aspx" --> <!--optionally strip angle brackets on public login and registration screens--> <!--use as persistent cookie expiration. Value is in minutes, and only active if a non-zero figure--> language="vb" type="Microsoft.VisualBasic.VBCodeProvider, System, Version=2.0.0.0, Culture=neutral, PublicKeyToken=B77A5C561934E089" extension=".VB" /> validationKey="F9D1A2D3E1D3E2F7B3D9F90FF3965ABDAC304902" decryptionKey="F9D1A2D3E1D3E2F7B3D9F90FF3965ABDAC304902F8D923AC" decryption="3DES" validation="SHA1"/> <!-- HttpModules for Common Functionality --> <!-- add name="Authentication" type="DotNetNuke.HttpModules.AuthenticationModule, DotNetNuke.HttpModules.Authentication" / --> <!-- This is for FTB 3.0 support --> <!-- This is for CAPTCHA support --> <!-- This is for Serving files, secure, insecure, from database --> <!-- set code access security trust level - this is generally set in the machine.config --> <!-- set debugmode to false for running application --> <!-- register your app_code subfolders to generate granular assemblies during compilation --> <!-- permits errors to be displayed for remote clients --> <!-- Forms or Windows authentication --> <form>s name=".DOTNETNUKE" protection="All" timeout="60" cookieless="UseCookies"/> <!-- --> <!-- allow large file uploads --> <!-- GLOBALIZATION This section sets the globalization settings of the application. Utf-8 is not supported on Netscape 4.x If you need netscape compatiblity leave iso-8859-1. UTF-8 is recommended for complex languages --> culture="en-US" uiCulture="en" requestEncoding="UTF-8" responseEncoding="UTF-8" fileEncoding="UTF-8"/> <!----> <!-- page level options --> <!-- ASP.NET 2 Membership/Profile/Role and AnonymousAuthentication Providers --> <!-- anonymousIdentification configuration: enabled="[true|false]" Feature is enabled? cookieName=".ASPXANONYMOUS" Cookie Name cookieTimeout="100000" Cookie Timeout in minutes cookiePath="/" Cookie Path cookieRequireSSL="[true|false]" Set Secure bit in Cookie cookieSlidingExpiration="[true|false]" Reissue expiring cookies? cookieProtection="[None|Validation|Encryption|All]" How to protect cookies from being read/tampered domain="[domain]" Enables output of the "domain" cookie attribute set to the specified value --> enabled="true" cookieName=".ASPXANONYMOUS" cookieTimeout="100000" cookiePath="/" cookieRequireSSL="false" cookieSlidingExpiration="true" cookieProtection="None" domain=""/> defaultProvider="AspNetSqlMembershipProvider" userIsOnlineTimeWindow="15"> <!-- Configuration for DNNSQLMembershipProvider: connectionStringName="string" Name corresponding to the entry in section where the connection string for the provider is specified passwordAttemptThreshold="int" The number of failed password attempts, or failed password answer attempts that are allowed before locking out a user?s account passwordAttemptWindow="int" The time window, in minutes, during which failed password attempts and failed password answer attempts are tracked enablePasswordRetrieval="[true|false]" Should the provider support password retrievals enablePasswordReset="[true|false]" Should the provider support password resets requiresQuestionAndAnswer="[true|false]" Should the provider require Q & A minRequiredPasswordLength="int" The minimum password length minRequiredNonalphanumericCharacters="int" The minimum number of non-alphanumeric characters applicationName="string" Optional string to identity the application: defaults to Application Metabase path requiresUniqueEmail="[true|false]" Should the provider require a unique email to be specified passwordFormat="[Clear|Hashed|Encrypted]" Storage format for the password: Hashed (SHA1), Clear or Encrypted (Triple-DES) description="string" Description of what the provider does --> type="System.Web.Security.SqlMembershipProvider" connectionStringName="SiteSqlServer" enablePasswordRetrieval="true" enablePasswordReset="true" requiresQuestionAndAnswer="false" minRequiredPasswordLength="7" minRequiredNonalphanumericCharacters="0" requiresUniqueEmail="false" passwordFormat="Encrypted" applicationName="DotNetNuke" description="Stores and retrieves membership data from the local Microsoft SQL Server database" /> defaultProvider="Ftb3HtmlEditorProvider"> <!-- FTB options: ============ toolbarStyle="Office2003|OfficeXP|Office2000|OfficeMac" Sets the default FTB Toolbar style enableProFeatures="[true|false]" Pro features require a license from FreeTextBox or you may test them with localhost only spellCheck="[{none}|IeSpellCheck|NetSpell]" IeSpellCheck is free for non-commercial use only NetSpell requires some integration work --> name="Ftb3HtmlEditorProvider" type="DotNetNuke.HtmlEditor.Ftb3HtmlEditorProvider, DotNetNuke.Ftb3HtmlEditorProvider" providerPath="~\Providers\HtmlEditorProviders\Ftb3HtmlEditorProvider\" toolbarStyle="Office2003" enableProFeatures="false" spellCheck=""/> defaultProvider="SolpartMenuNavigationProvider"> name="SolpartMenuNavigationProvider" type="DotNetNuke.NavigationControl.SolpartMenuNavigationProvider, DotNetNuke.SolpartMenuNavigationProvider" providerPath="~\Providers\NavigationProviders\SolpartMenuNavigationProvider\"/> name="DNNMenuNavigationProvider" type="DotNetNuke.NavigationControl.DNNMenuNavigationProvider, DotNetNuke.DNNMenuNavigationProvider" providerPath="~\Providers\NavigationProviders\DNNMenuNavigationProvider\"/> name="DNNTreeNavigationProvider" type="DotNetNuke.NavigationControl.DNNTreeNavigationProvider, DotNetNuke.DNNTreeNavigationProvider" providerPath="~\Providers\NavigationProviders\DNNTreeNavigationProvider\"/> name="DNNDropDownNavigationProvider" type="DotNetNuke.NavigationControl.DNNDropDownNavigationProvider, DotNetNuke.DNNDropDownNavigationProvider" providerPath="~\Providers\NavigationProviders\DNNDropDownNavigationProvider\"/> name="ASP2MenuNavigationProvider" type="DotNetNuke.NavigationControl.ASP2MenuNavigationProvider, DotNetNuke.ASP2MenuNavigationProvider" providerPath="~\Providers\NavigationProviders\ASP2MenuNavigationProvider\"/> defaultProvider="ModuleIndexProvider"> name="ModuleIndexProvider" type="DotNetNuke.Services.Search.ModuleIndexer, DotNetNuke.Search.Index" providerPath="~\Providers\SearchProviders\ModuleIndexer\"/> defaultProvider="SearchDataStoreProvider"> name="SearchDataStoreProvider" type="DotNetNuke.Services.Search.SearchDataStore, DotNetNuke.Search.DataStore" providerPath="~\Providers\SearchProviders\SearchDataStore\"/> defaultProvider="SqlDataProvider"> name="SqlDataProvider" type="DotNetNuke.Data.SqlDataProvider, DotNetNuke.SqlDataProvider" connectionStringName="SiteSqlServer" upgradeConnectionString="" providerPath="~\Providers\DataProviders\SqlDataProvider\" objectQualifier="" databaseOwner="dbo"/> defaultProvider="DBLoggingProvider"> name="XMLLoggingProvider" type="DotNetNuke.Services.Log.EventLog.XMLLoggingProvider, DotNetNuke.XMLLoggingProvider" configfilename="LogConfig.xml.resources" providerPath="~\Providers\LoggingProviders\XMLLoggingProvider\"/> name="DBLoggingProvider" type="DotNetNuke.Services.Log.EventLog.DBLoggingProvider.DBLoggingProvider, DotNetNuke.Provider.DBLoggingProvider" providerPath="~\Providers\LoggingProviders\Provider.DBLoggingProvider\"/> defaultProvider="DNNScheduler"> name="DNNScheduler" type="DotNetNuke.Services.Scheduling.DNNScheduling.DNNScheduler, DotNetNuke.DNNScheduler" providerPath="~\Providers\SchedulingProviders\DNNScheduler\" debug="false" maxThreads="1"/> defaultProvider="DNNFriendlyUrl"> name="DNNFriendlyUrl" type="DotNetNuke.Services.Url.FriendlyUrl.DNNFriendlyUrlProvider, DotNetNuke.HttpModules.UrlRewrite" includePageName="true" regexMatch="[^a-zA-Z0-9 _-]" /> defaultProvider="FileBasedCachingProvider"> name="FileBasedCachingProvider" type="DotNetNuke.Services.Cache.FileBasedCachingProvider.FBCachingProvider, DotNetNuke.Caching.FileBasedCachingProvider" providerPath="~\Providers\CachingProviders\FileBasedCachingProvider\"/> name="BroadcastPollingCachingProvider" type="DotNetNuke.Services.Cache.BroadcastPollingCachingProvider.BPCachingProvider, DotNetNuke.Caching.BroadcastPollingCachingProvider" providerPath="~\Providers\CachingProviders\BroadcastPollingCachingProvider\"/> defaultProvider="ADSIAuthenticationProvider"> type="DotNetNuke.Security.Authentication.ADSIProvider, DotNetNuke.Authentication.ADSIProvider" providerPath="~\Providers\AuthenticationProviders\ADSIProvider\" /> type="DotNetNuke.Security.Membership.AspNetMembershipProvider, DotNetNuke.Provider.AspNetProvider" providerPath="~\Providers\MembershipProviders\AspNetMembershipProvider\"/> type="DotNetNuke.Security.Membership.DNNRoleProvider, DotNetNuke.Provider.DNNProvider" providerPath="~\Providers\MembershipProviders\DNNMembershipProvider\"/> type="DotNetNuke.Security.Profile.DNNProfileProvider, DotNetNuke.Provider.DNNProvider" providerPath="~\Providers\MembershipProviders\DNNMembershipProvider\"/>
George Tang
Nuke Ace Posts:54
01/17/2007 5:31 AM |
This is the old web.config <!-- register local configuration handlers --> <!-- the requirePermission attribute will cause a syntax warning - please ignore - it is required for Medium Trust support--> <!-- Connection String for SQL Server 2005 Express --> <!-- Connection String for SQL Server 2000/2005 name="SiteSqlServer" connectionString="Server=(local);Database=DotNetNuke;uid=;pwd=;" providerName="System.Data.SqlClient" /> --> <!-- Connection String for SQL Server 2005 Express - kept for backwards compatability - legacy modules --> <!-- Connection String for SQL Server 2000/2005 - kept for backwards compatability - legacy modules --> <!-- Host Header to remove from URL so "www.mydomain.com/johndoe/Default.aspx" is treated as "www.mydomain.com/Default.aspx" --> <!--optionally strip angle brackets on public login and registration screens--> <!--use as persistent cookie expiration. Value is in minutes, and only active if a non-zero figure--> <!-- HttpModules for Common Functionality --> <!-- add name="Authentication" type="DotNetNuke.HttpModules.AuthenticationModule, DotNetNuke.HttpModules.Authentication" / --> <!-- This is for FTB 3.0 support --> <!-- This is for CAPTCHA support --> <!-- This is for Serving files, secure, insecure, from database --> <!-- set code access security trust level - this is generally set in the machine.config --> <!-- set debugmode to false for running application --> <!-- permits errors to be displayed for remote clients --> <!-- Forms or Windows authentication --> <form>s name=".DOTNETNUKE" protection="All" timeout="60" cookieless="UseCookies" /> <!-- --> <!-- allow large file uploads --> <!-- GLOBALIZATION This section sets the globalization settings of the application. Utf-8 is not supported on Netscape 4.x If you need netscape compatiblity leave iso-8859-1. UTF-8 is recommended for complex languages --> <!----> <!-- page level options --> <!-- ASP.NET 2 Membership/Profile/Role and AnonymousAuthentication Providers --> <!-- anonymousIdentification configuration: enabled="[true|false]" Feature is enabled? cookieName=".ASPXANONYMOUS" Cookie Name cookieTimeout="100000" Cookie Timeout in minutes cookiePath="/" Cookie Path cookieRequireSSL="[true|false]" Set Secure bit in Cookie cookieSlidingExpiration="[true|false]" Reissue expiring cookies? cookieProtection="[None|Validation|Encryption|All]" How to protect cookies from being read/tampered domain="[domain]" Enables output of the "domain" cookie attribute set to the specified value --> <!-- Configuration for DNNSQLMembershipProvider: connectionStringName="string" Name corresponding to the entry in section where the connection string for the provider is specified passwordAttemptThreshold="int" The number of failed password attempts, or failed password answer attempts that are allowed before locking out a user?s account passwordAttemptWindow="int" The time window, in minutes, during which failed password attempts and failed password answer attempts are tracked enablePasswordRetrieval="[true|false]" Should the provider support password retrievals enablePasswordReset="[true|false]" Should the provider support password resets requiresQuestionAndAnswer="[true|false]" Should the provider require Q & A minRequiredPasswordLength="int" The minimum password length minRequiredNonalphanumericCharacters="int" The minimum number of non-alphanumeric characters applicationName="string" Optional string to identity the application: defaults to Application Metabase path requiresUniqueEmail="[true|false]" Should the provider require a unique email to be specified passwordFormat="[Clear|Hashed|Encrypted]" Storage format for the password: Hashed (SHA1), Clear or Encrypted (Triple-DES) description="string" Description of what the provider does --> <!-- FTB options: ============ toolbarStyle="Office2003|OfficeXP|Office2000|OfficeMac" Sets the default FTB Toolbar style enableProFeatures="[true|false]" Pro features require a license from FreeTextBox or you may test them with localhost only spellCheck="[{none}|IeSpellCheck|NetSpell]" IeSpellCheck is free for non-commercial use only NetSpell requires some integration work --> |
George Tang
Nuke Ace Posts:54
01/17/2007 5:37 AM |
Sorry , seems cannot send the code. I have sent the files to your mail box. Please check
Thank you |
01/17/2007 6:13 AM |
ok, thanks for the code, there are a few elements missing from your new web.config file which you need to transfer across from you old web.config file. - These details were covered in the upgrade video tutorial.
<add key="InstallationDate" value="11/23/2006" />
<machineKey validationKey="A722820E0DFCEF2F87843244D095E51F976C6196" decryptionKey="AEC1A3C6FAAA77CF4C65E39F81BC3DD939FF920B09C6E768" decryption="3DES" validation="SHA1" /> These 2 pieces are most important to transfer across.
I have emailed you an edited web.config file so that you can see the bits transferred across.
Thanks, |
George Tang
Nuke Ace Posts:54
01/17/2007 6:20 AM |
Thank you for your help.
However, the browser still complains cannot open the page. |
George Tang
Nuke Ace Posts:54
01/17/2007 7:11 AM |
Or Let me clarify what i have done to see if i have got sth wrong.
First replace the web.config and then replace all the files from DotNetNuke_4.4.0_Upgrade folder. Build and Run it and it will update.
That's it. right>?
Thank you |
