Subject: Problem with IE
Ventana
05 Jan 2007 9:57 AM
I'm having a problem with one of the pages in my site, http://www.ventana-crc.com/scheduled+measurement+system+-+measures.aspx. When I open the page in either Safari or Firefox, and click on any of the links under the subhead "Sample SMS Assessment Battery", I can see the brief description on the right side of the page. However, when I open the same page in IE6, the brief description appear on for a few seconds before IE refreshes the page and it disappeared. Please advise how I could fix this. The javascript I'm using for this is:
function blocking(nr)
 if (document.layers)
     document.layers['QRS'].display = 'none';
     document.layers['CRT'].display = 'none';
     document.layers['DA'].display = 'none';
     document.layers['DSST'].display = 'none';
     document.layers['DV'].display = 'none';
     document.layers['DWR'].display = 'none';
     document.layers['STM'].display = 'none';
     document.layers['CFF'].display = 'none';
     document.layers['BP'].display = 'none';
     current = (document.layers[nr].display == 'none') ? 'block' : 'none';
  document.layers[nr].display = current;
 else if (document.all)
     document.all['QRS'].style.display = 'none';
     document.all['CRT'].style.display = 'none';
     document.all['DA'].style.display = 'none';
     document.all['DSST'].style.display = 'none';
     document.all['DV'].style.display = 'none';
     document.all['DWR'].style.display = 'none';
     document.all['STM'].style.display = 'none';
     document.all['CFF'].style.display = 'none';
     document.all['BP'].style.display = 'none';
  current = (document.all[nr].style.display == 'none') ? 'block' : 'none';
  document.all[nr].style.display = current;
 else if (document.getElementById)
  document.getElementById('QRS').style.display =  'none';
  document.getElementById('CRT').style.display =  'none';
  document.getElementById('DA').style.display =  'none';
  document.getElementById('DSST').style.display =  'none';
  document.getElementById('DV').style.display =  'none';
  document.getElementById('DWR').style.display =  'none';
  document.getElementById('STM').style.display =  'none';
  document.getElementById('CFF').style.display =  'none';
  document.getElementById('BP').style.display =  'none';
  vista = (document.getElementById(nr).style.display == 'none') ? 'block' : 'none';
  document.getElementById(nr).style.display = vista;
RE: Server Application Unavailable from localhost by picoallen
OK, I've got things working better now. Not sure why though as I lost track while following all the ...
e-Survey? by mgordon
I need a module that will do the following:When a person comes to a specific page (recreation guide ...
