Subject: Skin missing banner and menu when ctl is used in the url
Scott
09 Mar 2010 8:44 AM
OK, hopefully I explain this well.  I have a module (Ventrian's News Article) that allows me to launch the links outside of other modules (Live Tabs).  When I do choose to launch links it puts the ctl in the url and I loose my menu, which is a module called xmenu and my banner which is an html module.
Is there any way to add these so that they display when the url includes the ctl?
Example at http://asa.bellevuene.org/YouthSoftball.aspx.  Click on any of the District tabs and open a news article to see what I am referring to.
Any help is much appreciated.
Scott
WinXnet
09 Mar 2010 9:52 AM
Is your menu a module as well?
Is your banner HTML module set to "publish on all pages", or is it manually pulled in via "publish existing module"?
^_^Emerson
Scott
09 Mar 2010 1:18 PM
The menu is a module and it is set to publish on all pages. The HTML module is not set to publish to all pages.
WinXnet
09 Mar 2010 2:34 PM
What version of DNN?
Emerson ^_^
WinXnet
09 Mar 2010 2:52 PM
you're site appears to be down...
Scott
11 Mar 2010 9:18 AM
Sorry about that. That was my test domain and I just switched it to the permanent....http://www.nebraskasoftball.org
Version 5.1.4 of DNN
11 Mar 2010 6:27 PM
Is this fixed now?
Scott
17 Mar 2010 12:17 PM
No, I still don't have a solution for this
17 Mar 2010 3:26 PM
WinXnet
24 Mar 2010 8:25 AM
Is there an option with this module to create a new page for each article versus using a dynamically created page. I know I have had some issues with dynamic news pages...
GeishaMX ^_^
WinXnet
24 Mar 2010 8:27 AM
If you notice, your terms and privacy page do the same thing - even if you have "display on all pages" checked for the module.
Scott
24 Mar 2010 5:03 PM
Posted By Joseph Craig on 17 Mar 2010 3:26 PM
http://www.nebraskasoftball.org/YouthSoftball.aspx
Click any of the news articles and you will see the issue
Scott
31 Mar 2010 10:42 AM
Can anyone help with this?
31 Mar 2010 4:13 PM
I may be thinking a bit more clearly today ...
The "ctl" in the URL indicates that this is an "administrative" page.  The first question is ... why?  I believe that you are using Ventrian's News Articles module, but I don't know why the articles should appear in an administrative page.  You might want to look at how the module is configured, and also where the News Articles module is located.  This is the page on which the articles are actually displayed.
Also, look and see if the admin skin deletes the menu and/or the banner.
Knowing a bit more would help understand the problem, and its cure.
31 Mar 2010 4:17 PM
I should add that this might be related to the way that the module is embedded in the Live Tabs module. I have not used this module before.
I should also add that I have used the Ventrian News Articles module on a number of sites. I've never seen the article view come up in a "ctl" page.
Scott
05 Apr 2010 5:15 PM
My admin skin is the same as the site skin. Why or how would the admin skin remove the menu and banner?
Scott
05 Apr 2010 5:16 PM
I have also never had this happen before with Ventrian modules so I am at a loss right now. What other information do you require?
WinXnet
07 Apr 2010 8:05 AM
This is because the menu and banner content are modules, they are not in the skin.
Some pages that are created by dnn remove all but the content area specific items - terms, privacy, some modules. They also automatically use the home page skin, I beleive.
There may be a couple ways around this:
1) Do your menu modules have skin object versions? You can use these and they will appear anywhere since they are in the Skin. You may have to hard code the menu skin object and the html in the banner pane in the skin, at least on the home page skin.
2) Your module may have an option to set the page that is used for certain areas - I am not familiar with this module, but you could contact customer support.
While the idea of menu modules is great, they do still have issues, mostly due to the way DNN creates some of the dynamic pages.
07 Apr 2010 9:10 AM
Thanks.  That is a good answer.
Now, the question is why do those pages appear to be admin pages?
Forums > DotNetNuke® > DotNetNuke® Questions > Skin missing banner and menu when ctl is used in the url
RE: Skin Header by mcmanta
I'm not aware of any.
RE: Skin Header by WinXnet
RE: Slow login by jncraig
