Subject: Localized ressources
jumatthey
29 Jan 2010 8:23 AM
I would like to add localized ressources on a page like this :
<%$ Resources:MyRessource, String1 %>
I have put the Myssource.lng-LNG.resx file in the App_GlobalRessources folder.
But this doesn't work. I have an error on the page I want to display. How can I add customized labels on a page using the <%$ Resources:MyRessource, String1 %> tag ??
Thank you for information
JM
jumatthey
01 Feb 2010 10:46 AM
up
01 Feb 2010 6:56 PM
Use the TEXT skin object.
You will find additional documentation here.
jumatthey
02 Feb 2010 2:15 AM
Thank you.
Could you please provide me with an example ? This would be very useful for me.
Thank you very much
jumatthey
02 Feb 2010 3:05 AM
I have set up a test TEXT tag so :
< dnn:TEXT runat="server" ID="mytext1" Text="String1" ResourceKey="test" ReplaceTokens="true" / >
Now I have put a test.resx in the App_GlobalResources folder but it seems my text isn't translated. What am I doing wrong ? I have also put this line in my ressource file : name:String 1 value:Ceci est un test
It seems there is no link with my ressource file. Where should I put it insted of App_GlobalResources ?
Thank you for information.
02 Feb 2010 8:59 AM
DotNetNuke does not automatically translate text.  You need to have "language packs" installed for each language.  The language pack include resource files for a specific language.  So, you will need to add test.resx files for each of the languages that you support.
You will need to follow the structure and naming conventions for each of the languages.
jumatthey
02 Feb 2010 9:28 AM
I would like just one label to be localized. How do I do this ? Which token do I use ? Can you provide me with a code sample please ?
02 Feb 2010 9:41 AM
I am hardly expert in localization issues.  But, it appears that the German DNN group is one place to go for help (www.dnn-usergroup.de).
What you will need to do, based on a quick look, is provide a resource file for each language.  Inside of the resource file, you will translate your text.  If you've installed the correct language packs and also the localization skin object so that you can switch languages, DotNetNuke will pull the localized string from the appropriate resource file.  You'll need to name the resource files appropriately, too.  Once you have installed a language pack, you can see how that is done.
To me, it looks like you duplicate the resource files, and append language indicators to the file names. That's at least a place to begin.
jumatthey
02 Feb 2010 9:58 AM
Thank you for you reply.
This is exactly what I have done already. I have built a custom module called gridview.ascx in the Desktop Modules directory. From there I have a App_LocalResources folder in my module folder and then three ressource files named after each language that is : gridview.ascx.resx, gridview.ascx.fr-FR.resx, gridview.ascx.de-DE.resx.
Then I have a test1 line in each of my resource file.
Then on my ascx page I try to call from these files with this tag :
< dnn:TEXT runat="server" ID="mytext1" ResourceKey="test1" Visible="true" / >
I have put "test1" in the ResourceKey label so I think it should call this line from the ressource files, depending on current selected local. And yes I have installed all the necessary language and I can switch from one another through flags on top of the page. All my pages are actually successfully localized, except for this custom module I have build.
It seems I dont know how to use the appropriate tag to call from the ressource files, tho I have put them in the App_LocalResources folder in my module folder. This is how it is done with the other built-in modules.
Seems I am doing something wrong here, which is I can't call from the ressource file.
Thank you for support
JM
03 Feb 2010 9:21 AM
If you look at the Minimal Extropy skin, you will find this:
         < dnn:TEXT runat="server" id="dnnTEXT" CssClass="breadcrumb_text" Text="You are here >" ResourceKey="Breadcrumb" / >
The TEXT skin object is documented here.  It has several attributes.  They include:
  • Text  -- The text to display if there is no text available from a resource file. This is also the name of the key in the resource file that will be used
  • resourceKey -- The name of the resource file (*.resx) to use.
In your example, the resource file would be test1.*.resx.  You didn't include Text as an attribute, so the skin object doesn't know which key to use.
As I said, I'm not an expert here, but this is where I would look.
jumatthey
16 Feb 2010 3:57 AM
Still looking for a way to localize my labels. This way -> <%$ Resources:MyRessourceFile, Key %>
That is without breaking up DNN and generating errors.
If anyone has any experience with this, thanks for letting me know.
Regards
JM
Forums > DotNetNuke® > DotNetNuke® Questions > Localized ressources
That will work.
