Subject: Cannot show chinese
thtang
27 Nov 2006 9:23 AM
I have a aspx file which can be compiled individually under MS  Web development Express Edition. It can show Chinese character (Big5) properly.
However, when I put that file in dnn and compile it together. What I see in page is some mess code like
dd/mm/yyyy G m 魫G kg pqܡG *ݶg E-mail G pɶG W U ߤW ɶ ¾~G AMߡG (̤p) 1 2 3 4 5 6 7 8
Would you please give me some advices on solving this?
Thank you.
Forums > DotNetNuke® > DotNetNuke® Questions > Cannot show chinese
Have a look at the tabs table
page publish date by dnnwebuser
HiI would like to know the table to get page information(page name,publish date and time).Could you ...
RE: Keep Testing Skins by leesykes
For the downloads from DNN Creative you should not have to rename.When you upload the skin zip it sh...
RE: Old style skinning by leesykes
If you are using the logo skin object you should not get any repeat problems. I can't really tell fr...
Have you tried to re-apply the permissions for Network Service across the entire installation files?...
I have not added line breaks in before like that, most of the time I would setup a menu to just wrap...
on the part 6 page, amongst the video links is a link named:Vortex Music Skin Stage OneThese are the...
RE: Query regarding Site Log by leesykes
Once you start enabling logs, also make sure you schedule to delete the old logs:Site logs, Event lo...
RE: How to speed DNN by vdelisi
It could be related to the use uf resx file to localize the portal. I'm thinking about that becau...
Keep Testing Skins by ollep
Thanks for your reply Yesterday Lee. I will do a new upload and see if I can get the template worki...
RE: 3Essentials Hosting by nlssolutions
I wanted to post an update about 3Essentials. I had a few struggles with speed and some modules tim...
RE: Old style skinning by adrian_scott_day
Lee, The Logo skin object doesn't seem to have a property for setting a CSS Class. I'm using the sk...
RE: redirecting registered user to a specific page by jncraig
Go to the User Settings page under Admin. On that page, pull down the menu and click on User Settin...
RE: Building a website with DNN by jncraig
At the bottom of the page you will see the links for the various parts of the tutorial.  If you clic...
RE: How do i change the global font of the site by balousta
Thank you for your advice, I have seen the  tutorials long time ago, but I'm not good in css in gene...
Lee,Thanks for your suggestion about checking event log.  Here's what I did...First, in site Admin>>...
redirecting registered user to a specific page by saintX
Hello,Is it possible to redirect a user after registration to a specific page? If yes, please tell m...
Solpartmenu and line breacks by saintX
Hello,I have to make linebreacks on Solpartmenu, okay I do it using . Bur the secound line appears o...
Hi Joe,   Thanks for your reply. I have looked at those links and I can't seem to find the files f...
RE: Query regarding Site Log by puuri
Joe is exactly right with his suggested fix for your problem. I am very new with DotNetNuke and ran...
