Subject: FCKEditor not displaying text in Rich Text Editor
Matt Merchant
24 Jun 2009 9:36 PM
Having frustrating time with the FCKEditor not displaying text properly when in Rich Text Editor mode.
When switching to either Basic Text Box or Source view, I can see the raw HTML.  In the rich text mode, if text is enclosed in < p > ... < / p > tags it does not display, or displays in microscopic size. Any other HTML tag renders properly.
So far I have tried....
Setting the "HTMLEncoding Output" option to Yes (from Default)
Setting the "Reverse HTML encode output" option to Yes (from Default)
Setting the "CSS Generator Mode" to Dynamic (from Static)
It does not appear to make a difference which skin I use - results are the same...
Have tried to edit from different computers / networks - results are same...
One additional clue - the FCKEditor works fine on my local development server. It does not work on my hosted production server (Verio). Verio does not allow for dynamic writing to web.config - has to be done manually - not sure if that is making a difference or not.
Any thoughts?
Thanks !
Matt
Matt Merchant
26 Jun 2009 10:46 AM
Anyone else seeing this problem with the FCKEditor?
Matt Merchant
26 Jun 2009 11:32 AM
One more symptom...when I change the FCK Editor preferences, they are not saved. I have made sure to check the "Portal" radio button prior to Applying the changes...
Any thoughts?
kiran
26 Jun 2009 2:53 PM
I am also facing problem with FCKeditor i need to change the default font color in FCKeditor,
any one has some idea on how to change the default color, post here
kiran
26 Jun 2009 6:35 PM
i did it finally, to many changes in FCKeditor text area, goto
\Providers\HtmlEditorProviders\Fck\FCKeditor\editor\css\fck_editorarea.css and make changes there(ex in body for background...) and important thing is clear the cache in the browser and refresh r run it again
01 Jul 2009 2:54 AM
hello,
If the settings are not being saved for the FCK editor, this may mean that the correct read and write permissions on your DotNetNuke installation files are not set. Contact your hosting provider and ask them to reset the correct read and write permissions for running DotNetNuke (occasionally you may find that you need to reset permissions if you have made changes to the files on your website)
Regarding the display of the text - try this as a test, add some text to a page and then change the skin of the page to the default minimal extropy skin and see if the text displays correctly.
It sounds as though there is some skin CSS code resizing anything inside p tags
Forums > DotNetNuke® > DotNetNuke® Questions > FCKEditor not displaying text in Rich Text Editor
RE: Picture size limits by Doug_s
Morning, Thanks for the suggestion - a little different to this. This is a simple senario I add a ...
RE: query regarding page options by kaustav_kar
Thanks for your reply.Could you please let me know from where I can get the OWS module?Thanks
RE: How to Limit Access to Administrator Modules in DotNetNuke 5 - issue 50 by leesykes
Hello,Yes that's the only method I can see to make it work.Create a Tabs page - give edit permission...
RE: Uploading an MP3 file to my website by leesykes
If you are going to be uploading a lot of large MP3 files you may find it is best to use FTP, make a...
RE: Custom Textbox Size by leesykes
I can't see an easy way to do this with a standard text box, I've tried CSS styling the id and can't...
RE: query regarding page options by leesykes
hello,If you do not wish your visitors to login, then I think the only other option will be to use c...
Localizing Skins and css dynamically based on language selected by sadabahar83
Hi, I want to dynamically assign a skin and CSS based on the language selected. Different pag...
Recomended DNN version? by lolorn
What version of DNN would be recommended for creating a new site? Has DNN 5.2 turned out to be as st...
Hi,My site will have two Home pages, one for a new visitor and one for a returning visitor.   Is the...
RE: Plz Help. Page_Load_Exception by zaidkhan
URL of My website is www.pafkiet.edu.pk
Few new skins by Rozo
Skins for DNN and other CMS. www.stelg.com
RE: Plz Help. Page_Load_Exception by jncraig
Can you provide a URL?
RE: Custom Textbox Size by jncraig
For the second part, you can switch the editor to source mode and enter unstyled text. For the fi...
RE: Picture size limits by jncraig
The little red x's generally mean that the link to the image is broken.  My guess is that you have a...
RE: Uploading an MP3 file to my website by jncraig
web.config is in the root directory of your DotNetNuke installation.  ALWAYS (!!) make a backup copy...
RE: Customizing registration page by kana
I'm lost - I've just changed host and a few thing that used to work don't, plus I can't display anyt...
RE: How to Limit Access to Administrator Modules in DotNetNuke 5 - issue 50 by samjst
Hi, Did you manage to solve the problem? I'm facing the same issue: users with access to add and...
Ealo Tab Localization help by sadabahar83
hi, I have installed Ealo Core Api and Ealo tab localization and ealo Menu provider. menu is wor...
Custom Textbox Size by PopeOMalley
Hello everyone,Do you know if there is a way to customize the size of a textbox control on the Manag...
