hello,
Have you solved the problem as it seems to line up okay in IE7.
Looking at the content pane height, you need to look at this class:
.skinmaster {
its the height: 100%; that is causing the gap, if you take out this line you will see the footer move up the page.
You may want to checkout:
Troubleshooting DotNetNuke SkinsOn another note, I noticed using the web developer toolbar that the skin.CSS file is loading twice. This is caused by this line of code in your skin.html file:
< link href="/Portals/_default/Skins/funcnology-skin/skin.css" rel="stylesheet" type="text/css" / >
You do not need to add a link to the skin.CSS file in your skin.html file as DotNetNuke will automatically call in that CSS file, having a line of code in your skin.html file can actually cause you problems.
