Subject: Registration page
mlspector
01 Oct 2006 9:56 PM
How does one change the public statement on the registration page?  First, in 4.3 there are no * but red circle arrows for required fields and I would like to add an explanation of what the genenral registration page is used for and explan authorization.
10 Oct 2006 4:30 AM
To change the text on the registration page go to:
Host Menu
Languages
Language Editor
Local Resources
Admin
Security
App_LocalResources
Click on Register.ascx
Scroll down and look for:
PublicMembership.Text
or any of the other registration text details, they are all set from this page
Here you can edit the text to suit your needs
lisawalts
04 Dec 2006 2:30 PM
Hi. I did that and I am not seeing the changes. I am using DNN 3.3xxx and ASPNet 1.1. Also, the file it tells me I am changing is:
\admin\Security\App_LocalResources\Register.ascx.resx
Is that correct?
Help!
Lisa
05 Dec 2006 5:04 AM
Hello Lisa,
Yes you are right, I just tested it. Those settings must be for the actual Register module.
You can edit the text for the register page by going to:
Users
App_LocalResources
ManageUsers
The file to change is:
\admin\Users\App_LocalResources\ManageUsers.ascx.resx
Hope this helps, thanks,
wdarnellg
13 Jul 2008 2:36 PM
On my registration page the note below displays. I would like to edit this note, but I can't find the file that contains it. I have looked in the files shown above, but nothing pertaining to registrations is there. Can you direct me to the file that contains the note below?
Preferred User Information
*Note: Membership to this portal is Private. Once your account information has been submitted, the portal Administrator will be notified and your application will be subjected to a screening procedure. If your application is authorized, you will receive notification of your access to the portal environment. All fields marked with a red arrow are required.
13 Jul 2008 4:40 PM
Refer to the answer earlier in the thread. Go to Admin, Languages and open the language editor. The string you are looking for is named PrivateMembership.Text and is in the SharedResources.resx file.
wdarnellg
13 Jul 2008 11:47 PM
Thank you. That was the correct location. The Register.ascx part of the above answer threw me. I can't find that in my files.
Web.config Error by derpir
Yahoo Answers by cdtguru
RE: Videos by clippy
skinning trouble by derpir
RE: Template Issue by jncraig
