Subject: How can i change namespacename in my Dnn project
souravmoy_sau
15 Sep 2006 5:38 AM
Hello
I have created a DNN 4.3.4 project ..Now i want to change the namespace name (like DotNetNuke.aa to MyNamespace.aa) every where in my project so that while i type imports(or using),Mynamespace will appear instead of DotNetNuke. and i can get all the option after giving dot(.) as i was getting previously.
Please suggest me a way so that i can successfully do this..Please help me.
Thanks and regards
Sourav
Forums > DotNetNuke® > DotNetNuke® Questions > How can i change namespacename in my Dnn project
Firefox Does Not Display WMV File In Media Module by johnmk777
Hi All,I can't believe I am having such a hard time finding and answer to this question.  I have see...
