Subject: Submenu in HouseMenu
kshaikh
07 Sep 2006 7:06 PM
I am working on housemenu, it is working fine except the fact that submenu  like ADMIN and HOST menus have, their drop down items are shown as individual item in the menu bar instaed of being as a submenu items in drop down, can any one tel whats the problem and is it possible to have dropdown sub element like ADMIN and HOST have with HOUSEMENU
plz help me, i hop i clearly explained my problem
For Clarification i am pasting CSS code for HOUSEMENU
*********************skin.css**********************
#HouseMenuNav ul {
    font-family: Verdana;
    font-size: 11px;
    font-weight: bold;
    text-decoration: none;
    color:#fff;
    margin: 0;
    padding: 0;
    list-style:none;
#HouseMenuNav li {
    display:inline;
    background: url(/MyFirstSkinImages/greenbg.gif) repeat-x center top;
    text-align: center;
    padding: 0;
    margin-right: 4px;
    float: left;
#HouseMenuNav a {
    color: #663300;
    background: url(/MyFirstSkinImages/greenleft1.bmp) no-repeat left top;
    float: left;
    margin:    0;
    padding-left:7px;
#HouseMenuNav a span {
    background: url(/MyFirstSkinImages/greenright1.bmp) no-repeat right top;
    display: block;
    padding:7px 13px 4px 5px;
    float: none;
Kiran
08 Sep 2006 2:15 AM
I have not yet found a way to get a drop down menu to work reliably in the HouseMenu in IE7 (ie. to work like Solpart) so I just use static menus with the HouseMenu where the submenus are displayed along with the main menu items.
Eg. You can see this in action here: (This is for a vertical menu)
Free Skin - Simple Red Leaf CSS Skin
For a horizontal menu I have created a tutorial which demonstrates different methods for creating horizontal sub menus which is compatible with all browsers:
How to create Horizontal CSS menus in DotNetNuke using the HouseMenu
Hope this helps,
Forums > DotNetNuke® > DotNetNuke® Questions > Submenu in HouseMenu
