Subject: How can i create a nuke 4.3.4 project with C#
souravmoy_sau
05 Sep 2006 11:19 PM
Hello
I have instaleed DotNetNuke 4.3.4  in visual studio 2005.Using starter kit.Now while i am going to create a nuke project with language C#,i am not getting the DotNetNuke option to create a project which i am geting while creating a project with language Visual Basic.
Is it mean that I cant ceate a nuke project with language C#??? or is there any other way to create .If there is other way to create ,please please let me know.
i am really eager to know .Please help me to solve this problem...
Sourav Moy Sau
06 Sep 2006 2:22 AM
I have not set this up myself, but I have received this info from Parag Nikhal, hope this helps.
"I consider that you have develop a site in DNN 4.0 with visual studio 2005 so in that we have a dotnetnuke's starter kit for createing a VB.NET DNN 4.0 site...
after creating a site right click on root and add a module one dialog box will open for adding a module choose language as C#  in that and click OK..... then C# module will be created in same site...
major change is in web.config file....
<system.codedom>
<compilers>
<compiler language="vb" type="Microsoft.VisualBasic.VBCodeProvider, System, Version=2.0.0.0, Culture=neutral, PublicKeyToken=B77A5C561934E089" extension=".VB" />
<compiler language="C#" type="Microsoft.CSharp.CSharpCodeProvider, System, Version=2.0.0.0, Culture=neutral, PublicKeyToken=B77A5C561934E089" extension=".CS" />
<!-- add above line just change a PublicKeyToken as per your publickryToken-->
</compilers>
</system.codedom>
after this build a site...."
Forums > DotNetNuke® > DotNetNuke® Questions > How can i create a nuke 4.3.4 project with C#
