Subject: File Manager Wierdness
harlowj
02 Sep 2006 1:16 PM
Just installed a fresh copy of 3.3.4 and noticed that when logged in under admin or view the admin file manager that I've got folders there for contrainers and skins.
The interesting thing is that I can create a subfolder on the site through the file manager, delete it, and even syncronize and the directory does not go away. I've even checked on the server and there are no directories there. It is like it is got those directories in chache. I've restarted the webserver, recycled the app pool, everything and I cannot get those directories that are not even o nthe file system to go away from the file manager window.
Any ideas?
thanks
jason
harlowj
02 Sep 2006 1:21 PM
ok, found the suspect folders in the database (folders table) so I'm assuming my syncronize is not working.
thanks
jason
Forums > DotNetNuke® > DotNetNuke® Questions > File Manager Wierdness
