Subject: A question about filename code!
qibingyue
31 Aug 2006 10:46 PM
Hi,LEE!
http://photo.163.com/photos/qibingyue110/70065619/1940713844/
 This links a picture about my problem!
In my website   , i uploaded  the chinses file name , the filename in database is correct!  but when i click the 'download' button  the filename is wrong !
How to solve it?
02 Sep 2006 3:41 AM
I don't know, this sounds like a problem with the documents module, I would ask this in the main DotNetNuke forum for the documents project:
http://dotnetnuke.com/tabid/795/forumid/18/scope/threads/Default.aspx
thanks,
Forums > DotNetNuke® > DotNetNuke® Questions > A question about filename code!
