Subject: link / hyperlink between modules
bigb
31 Aug 2006 4:44 PM
Anyone know if it's possible to create links from a module on page X to another module on page Y?  -- probably a no brainer but not for me
much appreciated
02 Sep 2006 3:36 AM
Hello and welcome to the forum,
Do you mean you just want to create a hyperlink from one page to another?
If you do, then you can simply copy the URL from the page you want to link to in the browser window and paste that URL into the Text / HTML module on a separate page.
Please explain further if this is not what you mean, thanks,
bigb
02 Sep 2006 11:04 AM
thanks for responding Lee -- actually no, I want to link between "modules", either on the same page or different pages. I know how to link the pages, but not the directly to a given module.For now, I've used a single "document" in the same "module" with hyperlinks.
What I want to do is link from DETAIL in module A to CONTENT in module B (same page or different pages).
thanks again
b. stensrud
04 Sep 2006 2:42 AM
ok, all I can suggest for this is that you go to module B and view the content that you wish to link to and see if it has a URL with parameters which informs DNN to view that particular content in module B - Copy this URL and then paste it in Module A.
Forums > DotNetNuke® > DotNetNuke® Questions > link / hyperlink between modules
