Subject: "Service Unavailable"
tiktakit
25 Aug 2006 9:49 AM
I was trying to add my container another ascx container, using the install page (i added it to the zip, when navigated "install resources").
I made a clear container:
<%@ Control language="vb" CodeBehind="~/admin/Skins/skin.vb" AutoEventWireup="false" Explicit="True" Inherits="DotNetNuke.UI.Skins.Skin" %>
<%@ Register TagPrefix="dnn" TagName="ACTIONS" Src="~/Admin/Containers/SolPartActions.ascx" %>
<%@ Register TagPrefix="dnn" TagName="ICON" Src="~/Admin/Containers/Icon.ascx" %>
<%@ Register TagPrefix="dnn" TagName="TITLE" Src="~/Admin/Containers/Title.ascx" %>
<%@ Register TagPrefix="dnn" TagName="VISIBILITY" Src="~/Admin/Containers/Visibility.ascx" %>
<%@ Register TagPrefix="dnn" TagName="ACTIONBUTTON5" Src="~/Admin/Containers/ActionButton.ascx" %>
<%@ Register TagPrefix="dnn" TagName="ACTIONBUTTON1" Src="~/Admin/Containers/ActionButton.ascx" %>
<link rel="stylesheet" type="text/css" href="<%= SkinPath %>container.css">
      <TABLE class="containermaster_clear" cellSpacing="0" cellPadding="5" align="center" border="0">
        <TR>
          <TD id="ContentPane" runat="server" align="center"></TD>
        </TR>
        <TR>
          <TD>
            <TABLE  border="0" cellpadding="0" cellspacing="0">
              <TR>
                <TD align="left" valign="middle" nowrap><dnn:ACTIONBUTTON1 runat="server" id="dnnACTIONBUTTON1" /></TD>
                <TD align="right" valign="middle" nowrap></TD>
              </TR>
            </TABLE>
          </TD>
        </TR>
      </TABLE>
      <BR/>
which is without a "title". It used the same CSS file as another working continer in this page:
 Container Styles for DotNetNuke
.containermaster_compass {
    background-color:#FFFFFF;
.containerrow1_compass {
    background-image: url("home-title-blue-pixel.jpg");
    background-repeat:repeat-x;
    text-align:right;
.containerrow2_compass {
    background-color: #ffffff;
.head{
    color:#FFFFFF;
    font-family: Arial, Arial (Hebrew), David (Hebrew), Courier New (Hebrew);
    font-size: 14px;
    font-weight:bold;
    text-align:right;
.compass_text{
    text-align:right;
.containermaster_clear {
.containerrow1_clear {
    text-align:right;
.containerrow2_clear {
.clear_text{
    text-align:center;
After i uploaded it there were some errors ("unhandled errors"). Note: I used this continer inly to onw continer in the page (among of others).
So i tried to replcase the new continer code with the working continer code, because i wanted to change it step by step untill i figure what i did wrong.
But then i got: Service unavilibile. Since i can't check it its a server problem (although im logged to it, so its hard to believe to be a server problem) - i'd like to know if anytthing from what i've done above could have caused it ??....
tiktakit
03 Sep 2006 6:25 AM
It was solved.
Appearntly too many skin errors causing the DNN to close itself as applicaiton...
weird!
Forums > DotNetNuke® > DotNetNuke® Questions > "Service Unavailable"
