| RE: Add New Profile Properties by jncraig |
| Hmmm ... I don't have an answer. Does anyone else? |
| RE: No Access for me too by ristori |
| it is ok now. Thanks for this action. |
| skin/container error load by islandman |
| Has anyone else run across this error when loading skins or containers from site settings?I am using... |
| Email Set UP per Portal by islandman |
| How do I set up a unique email address per domain name off 1 hosting environment.
for example...m... |
| RE: localhost Install issues by cdees |
| Lee: I wanted to follow up on this for anyone following this thread. I have been unable to solve t... |
| RE: Add New Profile Properties by WSI |
| HI Joe, The DNN version is 4.5.5. Thanks, Cliff |
| Change Skin on URL by vinita |
| Hi,Can the skin be changed based on the url used to access a portal. Multiple portal aliases may be ... |
| problem creating child portal by kabamaro |
| Hello all i have 4 Aliases for my parent portal , lets call them X,y,Z,WIn all Aliases i can creat... |
| Best DNN portal ever! by derpir |
| I have been a subscriber since august 2008, and DNNCreative.com is simply the best DNN Portal, their... |
| RE: skinning trouble by derpir |
| Hello
Yes could you be so kind and take a look att the htm-file and css-file.I would be very gratef... |
| Search function is not working by kishorpawar |
| I am using Seach module in my project but not working, i have set host setting alsoHost --> Schedu... |
| RE: backend is changing from sql2005 to sql2008 by leesykes |
| hello,There should not be any code changes needed, but you'll need to make sure that SQL 2008 upgrad... |
| RE: skinning trouble by leesykes |
| Hello,I would need to see your code to help you with this one, you can zip up your files and attach ... |
| RE: Installing DotNetNuke 4.9.00 on VWD 2005 w/ SQL server 2008 by leesykes |
| I have run a test with SQL Server 2008 express and DotNetNuke installed in exactly the the same way ... |
| RE: Issue 39 Interview by leesykes |
| thanks Bill, glad it was useful, we will have a think about the best way to approach this,Thanks, |
| RE: Issue 39 Authentication by leesykes |
| yes I have a live site in 4.9.0 at it seems stable as well. |
| backend is changing from sql2005 to sql2008 by meenu |
| hi all
advance thanks.
in my DNN0408 website am using sql2005 as backend.now planning to remove sq... |
| About catalook error by kishorpawar |
| I am using dnn 4.8.4 version in my project, this site is in 2 language,whenver i click on the BYN... |
| RE: Menu Keeps Verticaly by ruimacdonald |
| Tnx for your help. It's done. Rui |
