Subject: Paths to thumnails incorrect in Skin manager
Cyberwolf
15 Aug 2006 4:21 PM
For some reason, all the thumbnail images do not appear in the skin manager. they show as broken image links. When you click on them, the large jpg image appears.
Looks like the path to the thumbnails is incorrect.
Incorrect:
http://dnnproductivity.powerwebbook.com/Admin/Skins/tabid/49/%5Cportals%5C_default%5Cskins%5Cdnn-blue%5Cthumbnail_horizontal%20menu%20-%20fixed%20width.jpg
when the graphic is loacated here:
http://dnnproductivity.powerwebbook.com/portals/_default/skins/dnn-blue/thumbnail_horizontal%20menu%20-%20fixed%20width.jpg
Any idea where the "Admin/Skins/tabid/49" in the path is coming from? How to fix?
ver 4.3.4
Forums > DotNetNuke® > DotNetNuke® Questions > Paths to thumnails incorrect in Skin manager
