Subject: Paypal
alain100
08 Oct 2008 9:32 PM
hi Lee,
I really enjoy your tutorials, they saved me quite a few times. Thanks.
I would like to know, what module do you use on your site for your subcription ? Is it the integrated Palpay in Dotnetnuke or you use another module. I checked your Paypal Sandbox videos and store module videos and it's interesting but this is not what I need on my site. I also watched the subscription with paypal video that's about what I need but I would like to be able to go directly to paypal after the registration, is this possible? something like on your website would be ideal
Alain
10 Oct 2008 10:34 AM
Glad to hear you like the tutorials, the module we use for subscriptions is www.ventrian.com subscription tools module, thanks,
