Subject: Home Page for MultiLanguage (SEO?)
vdelisi
03 Oct 2008 12:55 PM
Hi, I've a big dubt. I've a site with two languages, I'm using iFinity URL Reewriting provider, and now I've the following situation: If I access to the site with his address: www.saileasy.com I'm able to move in all the page, but the language parameter doesn't appear. If I click on a different language I've all the url with the langauge paramter in the URL, that is what I want. The main issue is for the Home page that produce duplicate content, I've a 301 redirector module but I'm not able to solve this with that module. I'm thinking that the solution could like www.pixmania.com that has a home page with the link to the real site for each language...but how can I do? Thanks Vincenzo
10 Oct 2008 9:09 AM
If you have a rewriter provider setup I would contact iFinity and ask for their suggestions on setup of their module, thanks,
johnsmith5082
08 Nov 2008 10:27 AM
Let me tell you that i get interested on this topic because i'm going to build a multilanguage site for a 4-star-Hotel with 5 languages (english, german, italian, french, russian) and that after several on-topic searches I've realized that this is still an open debate without a definitive good practice.
barbie
seo
Forums > DotNetNuke® > DotNetNuke® Questions > Home Page for MultiLanguage (SEO?)
