Subject: FCK Editor GoDaddy
02 Oct 2008 3:53 AM
My DNN in Godaddy cant not install the FCK Editor and other features, and I dont know what is the problem, I'm looking a solution. Can you help me? - David
Please ask questions in the forum rather than email me direct. What version of DotNetNuke are you using? - You can find this out by going to the host menu / host settings. - In later versions of DNN FCK Editor should be installed as default.
Forums > DotNetNuke® > DotNetNuke® Questions > FCK Editor GoDaddy
