Subject: Query regarding clearing cache
kaustav_kar
05 Sep 2008 8:26 AM
In my site which is in Dot Net Nuke to clear cache I want a button. Is there any code with the help of which I can do that.
Please haelp.
05 Sep 2008 8:34 AM
mgordon
05 Sep 2008 8:56 AM
Correct. It's at "Host Settings" / "Performance Settings" you'll see a link that says "Clear Cache".
Otherwise you'll need to modify the core code and that can be something that will hold you hostage for awhile. Not recommended.
Mark
Mark Gordon
Webmonkey
Forums > DotNetNuke® > DotNetNuke® Questions > Query regarding clearing cache
