Subject: User Accounts - Profile Property Display settings
dp6ai
05 Sep 2008 7:25 AM
I have added a new Profile Property to Users (Company name) Does anyone know how to change the layout of the user accounts page (normally tabid 42 I think)to display new Profile Properties. I have been into User Settings and can successfully add and remove standard properties from the User Accounts Settings section - but can't seem to find a way of displaying new accounts!
05 Sep 2008 8:43 AM
dp6ai
05 Sep 2008 9:41 AM
Thanks for clarifying that.
Just to confirm I have checked the Visible box on the Manage Profile Properties page.
It seems to be the check boxes for
"Show Name Column",
"Show Email Column"
etc.
on the User Accounts/User Settings/User Settings options that change which parameters are visible on the main User Accounts Page.
And I want to add my new option (company) here.
Does that make sense at all?
05 Sep 2008 10:59 AM
I would suggest you watch these tutorials:
Forums > DotNetNuke® > DotNetNuke® Questions > User Accounts - Profile Property Display settings
