Subject: page publish date
dnnwebuser
05 Sep 2008 5:35 AM
I would like to know the table to get page information(page name,publish date and time).
Could you please tell me in which table the details are getting stored and is there any api to intract with the db to get these page info
05 Sep 2008 5:56 AM
Have a look at the tabs table
dnnwebuser
05 Sep 2008 7:29 AM
05 Sep 2008 8:40 AM
This might help you: DotNetNuke.Entities.Users.OnlineUserInfo
It's always better to use the business objects rather than to go directly to a table.
dnnwebuser
05 Sep 2008 10:17 AM
Thanks Its working fine.
I have a clarification in Register section that after user registration,user will be created and when he logs in second time,he will be shown with the fields (street,Country.........),I have a requiremnt to show the street and country in the main registration page along with the username and password.
Could you please tell me is it possible,if so please tell me a way to achieve it
06 Sep 2008 9:54 AM
I'm not quite sure that I understand you, but ... on the user accounts page there are these options:
Require a valid Profile for Registration:
Require a valid Profile for Login:
06 Sep 2008 11:11 AM
I would suggest you view these tutorials:
