Subject: Top bar
crook_sam
21 Aug 2008 4:50 AM
Hi, forgive me but i am relatively new to all of this and. I want to try and change the bar that runs accross the top of the website (i am not sure what it is actually called but it is the part which displays your chosen logo in the top left and appears on every page). How do i go about designing and using my own one or perhaps using one found in another skin. Is it possible to change only this part easilly, i have no experience in skinning.
Thanks a lot
                   Sam.
21 Aug 2008 4:54 AM
Elements like this are easy to change with a bit of skinning knowledge, I would suggest you start by looking at Issue no 5 and 6 which starts you off from the very beginning and explains how to setup for skinning and the basic principles you need to get started, if you then carry on following the skinning tutorials through in issue number order you will become an advanced CSS skinner!
