Subject: Problem in front end
kaustav_kar
20 Aug 2008 12:23 AM
In my website which is in Dot Net Nuke is showing the control panel in the front end in all the pages. I've checked the admin as well as the settings of all the pages and it's ok. Why it's comming in the front end and how to remove that.
Please help.
20 Aug 2008 2:22 AM
The first place I would look is in your skin code, the code for the ControlPanel should look something like this:
< div id="ControlPanel" runat="server" >< / div >
(spaces have been added into the tags so that it displays correctly in the forum)
Forums > DotNetNuke® > DotNetNuke® Questions > Problem in front end
