Subject: dotnetnuke websites
dnnwebuser
18 Aug 2008 6:14 AM
I have created two dotnetnuke websites in the website root.
Could you please tell me will it create any problem ?
Thanks in advance
18 Aug 2008 8:20 AM
It depends. Did you create a second instance of DotNetNuke, or did you create two websites with a single installation?
Either will work just fine, provided that you set them up correctly.
Forums > DotNetNuke® > DotNetNuke® Questions > dotnetnuke websites
