Subject: How di I get to the admin login page
derpir
16 Aug 2008 9:28 AM
I have a newbie question:
I wonder if you could help me out.
After installning the DNN where do I login as admin on the DNN webpage?
could you please help me out? Your getting started videos doesnt say.
The adminpage I am looking for is that page where you login
as admin, admin on the DotNetNuke.com
best regards
16 Aug 2008 6:26 PM
Click the login link and login using the admin account and password. If you have installed with the "usual" options, the admin user's name is "admin" and the password is "dnnadmin." For the host account it is "host" and "dnnhost."
Forums > DotNetNuke® > DotNetNuke® Questions > How di I get to the admin login page
